Search instead for
Another Youview Pixelation
SBPartridge
Hi. I've had the Youview service for a number of years. Over the last six months the channels have started to pixelate and have now pretty much disappeared (at first channel 4 but now the BBC channels as well.) The internet/catchup/iplayer still work fine.
I thought maybe there was a problem with the aerial but my signal through the aerial is fine when I go straight to the telly.
As the problem seems to be with the box can I get a new box from TalkTalk and how do I do this? Thanks
Have you tried a full retune of the channels ?
If a retune does not change anything, try a Youview Maintenance Reset (Option 4: Keep Recordings).
set the box back up and retest all the channels.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
SBPartridge
Hi Karl. Yes I've tried that. It comes up with 'no channels found" - I had thought that this could be the aerial but the aerial is fine when plugged straight into the telly. How do I go about getting a replacement box? thanks
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
SBPartridge
I've done that thanks Karl. The phone is rarely plugged in on that number is I suffered a lot from nuisance calls
SBPartridge
Any update on this Karl please?
