Bad signal through youview box
4 REPLIES 4
We have on ongoing problem with the reception on our youview box. The reception is fine if you put aerial wire directly into TV so not an aerial problem.
I have tried retuning the TV and its OK for about 24hrs then the reception goes again. I've tried retuning without aerial wire to clear the system and a factory reset, none of which has sorted the problem long term.
Any suggestions?
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
I've updated my profile
The signal levels at the box do look poor.
I'll get a replacement TV Box out to you so this can be retested.
