Boost channels not working
10 REPLIES 10
My boost channels work for a short time sometimes then display error ip6023.
I have 53mb/s download at the router and my PS4 say 44mb/s. Youview box directly connected to router. I have reset everything.
Please help.
Mickyallsorts.
Hi @Mickyallsorts
Could you check for updates, Blue button on remote > Settings > Software Information > Update Software as this sometimes kicks boosts into action.
The other thing to try is More TV then play something from one of your boosts in Catch Up.
IMPORTANT !!!!!
Hi @Mickyallsorts
I'm picking up a fault on the line, tests are showing an earth fault and an unbalanced cable fault.
I've logged this out to Openreach for a non appointed engineer to take a look at the line.   If they then require an appointment we can go through the process with you.
Hi, Openreach have visited and fixed a problem in the cabinet, corroded cable.
Unfortunately the problem still exists.
Bandwidth is 50mb plus.
Latest update on Youview box.
Please help.
Mickyallsorts.
As your on fibre, now that openreach have been, can you power off all equipment for 30 minutes.  This will allow the current exchange session to clear.  Power back on and when all is back up and running, try the TV channels and let me know what happens, any errors etc.
Still no good I'm afraid. More TV on demand films and programs work fine.
Movie channels etc play for 5 mins or so then error 6023.
Mickyallsorts.
All line tests are clear and the line levels look so much better following the openreach engineer.
I've a different router on the way to you for testing, just to see if this will process the TV data and maintain a connection to the server.
The router I had was broken and detached from the stand when it arrived so that will be handy.
Will let you know how it goes.
Mickyallsorts.
Excellent. This is a different model of router, so I just want to compare how this handles TV for you.
Sorry for the delay, it is all working fine now.
Mickyallsorts.
That's great news, thanks for confirming.
