Boost channels pixelating
3 REPLIES 3
Gareth36
I have the entertainment and sky sports boost but find that these channels have a lot of pixelation.   All other channels are unaffected.   Any suggestions please on how I can fix this permanently.  Thank you
Gareth
fre55die
Hi @Gareth36
How is your box connected to your router? Is it directly with Ethernet cable or Powerline Adapters?
Gareth36
Hi it is connected with power line adapters
Gareth
fre55die
Hi @Gareth36
Do you have a long Ethernet cable that you can connect temporarily between the Router and the box, or move the box closer with a long HDMI lead so that you can do this?
Are all of the lights on both of them CONSTANTLY green with no Orange or Red occasional flashes on the centre one?
Is it possible for you to connect either a laptop or computer to the PLA by the box and run a speedtest from there ?
P ower L ine A dapters are notorious for occasional dropouts, which can cause your problems on these boosts, which need a continuous high speed connection. So this is just to rule these out as being the problem.
