Box freezing and restarting
7 REPLIES 7
My box has over the last few months began to crash a lot - freezing, which then needs a restart. This is becoming more and more frustrating as I am missing crucial parts of programmes.
Help
@empanther81 Hi can i asks a few thing how long have u had the current box ??
What happens as in the actual issue like the box does not respond to the remote control??
What have u tired to fix it like turned it off for 5 mins and have u do a reset on the maintenance side like option 2 keep recordings
have u tired turning ur router off for 10 mins if on normal b/b and 30 mins if on fibre
as could be a issue with a link on the network as we have found before
Hope that help Regards Joe
Hi. I've has the box for a I'd say 2 years.  I've tried all the resets etc.
The machine just freezes on page and will not respond at all
Hi @empanther81
When this happens do the buttons on the front of the box (+ and -) have any effect?  Is it just the picture freezing ?
Hi. None of the buttons have any effect. I have to unplug. The box will also restart its self randomly.
Hi again @empanther81
This has been escalated for OCE attention and they should respond on Monday when they are in, however they are running a "skeleton" staff over the break.
Is the box connected directly to the router by ethernet cable or "Power Line Adapters"? as they will ask this, also do you get any error messages ?
IMPORTANT !!!!!!
Thanks its direct via ethernet cable.
Hi empanther81
I'll swap out the box and see if this helps.
