Box not recording or playing old recordings
80Charlie
I've been unable to record or view recordings for a few months now but not been able to resolve the issue.
I don't really want to lose my recordings but I can't use the box as I should... could you please advise what I can do?
Box memory is currently 28% free.
fre55die
Hi @80Charlie
Could you try a Maintenance reset as follows, by selecting option 2 you will not lose your recordings.
Turn the box off, then unplug power lead for a couple of minutes.
Re plug in power .
  1. Ensure the YouView Box is switched off and is currently connected to the router (the YouView Box will require an internet connection).
  2. Power on YouView using button at the back of the YouView Box.
  3. Start YouView using the power button on the YouView Box front panel and then quickly press and hold both the + and – buttons on the front panel. If you haven’t pressed the buttons together by the time 'YouView Waking Up' is displayed, or you see the 'YouView please wait...' message then try again.
  4. Let go of the + and – buttons once the 'Huawei – Maintenance Mode menu' is displayed.
  5. The + and – buttons on the front panel will navigate the menu. Keep pressing the – button until 2 “factory reset keep recordings” option is highlighted. If you go past the option, simply press the + button to navigate back to the option.
  6. Press the power button on the YouView Box front panel to select the option. This will bring up some information and ask 'Do you want to proceed?'. Press the power button again to confirm.
  7. The YouView Box will now show a progress bar as it downloads software from the internet and installs on the YouView Box. This may take several minutes. Once complete, the YouView Box will restart.
  8. Once the YouView Box restarts, the YouView Box will show the initial setup wizard. You will need to run through the setup wizard including tuning the channels.
Duncan8
Tried the maintenance reset option 2 but has not cured the problem. Suggestions?
Duncan
hosay299
Insightful One
Duncan8
welcome please start ur own topic as the the team only help people in there own topic.
to do this click on new topic on the tv listing page here
Hope that help Joe R If so then give me a Kudos ( Click the Thumb up Button)
