Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Can’t Set Up TV Plus Box
Kipper1970
It’s now 2 weeks since I changed to TalkTalk and I still haven’t managed to get my tv box working. It starts set up but gets as far as setting up tv services and gets stuck. Does anyone have any ideas what I can do.
Can you check the phone number in your Community Profile
It looks to have 1 to many digits.
Check & Report l Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Kipper1970
Phone number sorted it had an extra 6
Is the youview box direct to the router or via powerline adapters ?
Are you able to test with a direct connection to the router ?
Kipper1970
Tried to connect via power line adapters. I can’t connect direct to the router. The powerline adapters are working as I have my old bt youview box working through them.
Is it not possible to take the TV box to the router just for the setup, possibly with a portable TV etc, and then when set up replace in the original location.
Kipper1970
I’ll try and sort something later
Kipper1970
Just tried to set up tv box connected directly to the router. I’m still getting the same problem with set up sticking on step 3 setting up tv services.
I've emailed our TV tech teams to have a look at this.
Kipper1970
Can you try a Youview Maintenance Reset
When the box has been fully reset try the set up again and see if it sticks at option 3.
