Channel 5 Catch Up
1 REPLY 1
I am still unable to watch any programmes in catch up. All I am getting is a blank screen. I understood there was an issue which they were trying to fix. I have re-tuned but it didn’t work. Is anyone else having this issue and have they managed to fix it. Thanks 😊
Have you manually tried to update the players under settings / software information? Try this first.
If that does not work then try a YouView Maintenance Reset
Hope it works but if not then please let us know and I’ll flag for further assistance.
