Search instead for
Christmas food TTG-202 error
ANSWERED
jimbob1986
Hi all my TV channels are working but i have the above ewrror on Christamas food/good food.
can you advise on a  fix please.
James Alderson
Gondola
Hi @jimbob1986
An obvious question but are you subscribed to the Entertainment Boost and can you receive other channels from the Entertainment Boost pack?
 Gondola - I'm a TVPlus customer *
jimbob1986
yes all the other ones i sub scibe to work except this one.
James Alderson
Hi jimbob1986
Can you turn the TV box off via the button at the back for 5 minutes, then back on and retest.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
jimbob1986
have tried this and no change.  i am using a humax box as the talk talk box is rubbish
James Alderson
OK, not sure of the menu layout for the Humax, but can you try the following :
Try manually setting the network connection on the YouView box, in the Settings Menu go to Network & Internet, toggle to Manual and then use the following:
IP address 192.168.1.100
Subnet mask 255.255.255.0
Default gateway 192.168.1.1
DNS 79.79.79.79  /  79.79.79.80
jimbob1986
ok wil ltry in a bit
James Alderson
jimbob1986
just tried this and it says unable to connect. when i click auto connect it works again but good food will not work.
James Alderson
This is a strange one.
You can try a maintenance reset of the Humax, set it back up and retest
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode
jimbob1986
Just done that and still the same. Did both options software reset and download
James Alderson
fre55die
Hi @OCE_Karl
I've got the entertainment package and tried 313 good food it came up with set up channel then TTG-202 not available error.
I subsequentl pressed blue button and subscribed channels 313 does not appear in the list. I don't know if this is a help or hindrance !!
Gondola
...and my Entertainment pack presents channel 313 without any problem, apart from having 12 days of Dave and Si's wacky sense of humour!
fre55die
Just a thought !!!
I'm on the legacy version, you've just upgraded  @Gondola haven't you ??? I've checked in my account and it should be available though. I don't think that I've ever tried to watch it before.
jimbob1986
Same on mine
James Alderson
fre55die
Hi @jimbob1986
Is this a new problem, have you been able to watch it before?
I've tried channel 313 last night on both my boxes and it was working.  Hairy Bikers Christmas food was on.
This is such a strange issue that only one channel would give this error.
HollyBy
TalkTalk Products Team
Hi @jimbob1986,
I just want to check something - how are you trying to access the channel? Through the Guide or by typing in the channel number? The error code TTG-202 is specific to the More TV app, so you would only see this if you go into More TV and try to access the channel through your boost in there. If you're trying to access via the Guide or the channel number, you should get an IPC error code. Could you let us know what the IPC error code is and then we can investigate further.
Thanks, Holly
jimbob1986
At first  it says channel needs to be set up. So press ok it does flashing do thing and says getting subscription information then gives the ttg-202 error channel unavailable
James Alderson
HollyBy
Thanks @jimbob1986, I'll pass this on to our technical team and see if they can figure out what's going on.
Thanks, Holly
jimbob1986
20171207_114153.jpg3
20171207_114142.jpg1
20171207_114149.jpg2
James Alderson
