Connecting to router
4 REPLIES 4
Tigpiglloyd90
Hiya,
I can’t connect the tv to the router despite all other devices being connected to the WiFi.
ive tried everything online, re booted, reset the Ethernet cable, mains, everything.constantly saying connecting to the router, times out, connects again.any ideas?
Lucy
fre55die
Hi @Tigpiglloyd90
How is your TV box connected to the router, Is it ethernet cable directly or via Power Line Adapters?
If PLA's are all 3 lights on both of them showing green with no occasional orange or red flickering on the middle ones?
VERY IMPORTANT FOR SUPPORT !!!!!!
Tigpiglloyd90
Thank you for your response...
yes connected to PLAs...all three green lights are on...I turned them off for 30 seconds and nothing and then after two minutes waited and pressed the button on the bottom right and nothing...
thanks
Lucy
fre55die
Hi @Tigpiglloyd90
I have escalated this to OCE support and they will respond on here A.S.A.P.
Please do not add anything on here OR start a new thread until an OCE responds as the system will see this as a new post and move you to the back of the queue.
Unfortunately the response times are extremely delayed and currently can take a couple of days instead of the usual matter of hours. Please bear with us as an OCE will get back to you as quickly as possible.
OCE_Karl
Are you able to connect the TV box to the router directly with an  ethernet cable an run through the set up process, does it work.  If so, then place the box back in the original position and see if it connects again ?
