DN372T.01.01.P no longer recording and not playing old recordings
kknasher
last week tvbox keeps "failed to record". also cannot play any previous recordings. tried channel rescan and maintenance reset keeping recordings. southwest region.
OCE_Karl
If the maintenance reset has not resolved, there could be some corruption of the hard drive.
Only option is to try a full factory reset from the settings menu.  This will clear the hard drive and set this back up again, but is the only option before a box is replaced.
Can you try this and try a couple of test recordings.
kknasher
I didn't want to loose some of the recordings. So I fixed it by taking lid off.  Used a SATA to USB3 cable to connect the disc drive to a PC with ubuntu (debian/linux) and used these steps:
1. dmesg   (to see any errors. it showed xfs error on sdc6 partition)
2. sudo umount /dev/sdc6
3. xfs_repair  /dev/sdc6  (didn't work since transaction log corrupted)
4. xfs_repair -L /dev/sdc6  to delete the log and fix filesystem
you might need sudo apt-get install xfsprogs
you can use sudo blkid   to list all the partitions.
working ok now.
