Error code YVM102
4 REPLIES 4
JanTab2107
For nearly a week now i have had a problem with accessing the players on my talk talk youview. The preview guide (which shows what is currently on) is also missing. We have contacted Talk Talk Technical help several times but have got nowhere in fixing this.
Our Powerline Adapters are not working properly. One has no lights and is emitting a sound while the other only has 2 lights.
We have also had a new router sent recently.
Please can someone look into this ASAP please.
Many thanks.
hosay299
Insightful One
A bite of info of Forum:
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:- Personal Profile > Personal Information
Hope that help Joe R If so then give me a Kudos ( Click the Thumb up Button)
fre55die
Hi @JanTab2107
Have you tried resetting and re-pairing your PLA's as this is your problem ? YMV102 is poor or no internet connection. How long have you had them for.?
https://support.youview.com/youview-box/error-messages/fix-for-yvm102
JanTab2107
Thank you for replying. Have looked at Powerline Adapters and they are not working. One has no lights at all. Looked into replacing them but the only thing we could find (The Extender Kit) seems to be too much to pay for just getting Talk Talk TV back.
Will look into after Christmas.
Many thanks
fre55die
Hi @JanTab2107
They are available from Currys and most other retailers
Example https://www.amazon.co.uk/TL-PA4010KIT-Powerline-Configuration-Required-UK/dp/B01BECPIMC/ref=sr_1_4?i...
The extenders that you refer to are to boost your Wi-Fi although they can also be used as simple PLA's.
