Failure to record
1 REPLY 1
murrayeugennie9
My box ofrten fails to wake up overnight causing failure to record the days programms.
failure of information on the guide is indication that all is not well. I keep having to
restart by turning off electricity after which the message says bo waking up and it is ok for a couple of days then off it goes again.  It is becoming a nuisance.  Any ideas please??????? Grumpy
Try a Youview Maintenance Reset (Option 2: Keep Recordings).
Set the box back up and test over the next few days and see if the performance improves.
