Faulty new Youview box
methley3
New replacement Youview box faulty.
1. TV channels breaking and unwatchable, OK straight from aerial to tv.
2. Keeps switching tv on after switching off.
3. Goes through full setup every time it is switched on.
All connections same as previous box, now cannot use it.
fre55die
Hi @methley3
Try disconnecting the aerial lead and doing a retune. It will show no channels found but, will clear the memory. Then retune with aerial plugged in.
Have you tried swapping out to different aerial leads as they have been known to fail or to pick up interference .
Hi @methley3
I've just answered your other thread.  Best to keep to the one thread so we can be consitent with answers etc.
