Faulty tv plus box
7 REPLIES 7
biggles56
I am experiencing exactly the same symptoms with my box as "Archaeoali "  describes, my box is
6yrs old i have been onto help lines 3 times and they want to go through the same reset procedure etc,which works for a short time and then fault reoccurs. Can someone out there authorize a new box for me.  thanks
Archaeoali
I've not had any luck yet, still waiting for a response. Still not able to record things I want to watch.
Hi biggles56
Can you add the Home phone number to your Community Profile rather than the mobile, so i can locate your account.
biggles56
Hello Karl
I have added my home phone number as requested
thanks
biggles56
Hello  karl
Hi biggles56
A replacement unit is on the way.
biggles56
Hi Karl
Thankyou very much for sorting this, new box came yesterday.
May I just comment that Talktalk need to look at the way they deal with complaints such as mine,
I feel the Helpline should be able to escalate these ,so a replacement can be authorized rather
than having to sign up to contact yourself and others. it was just frustrating.
thanks Again.
Sorry for the hassle, but glad to hear the box has arrived promptly for you.
