Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
HG663 dropping
DParker
Sightseer
My router keeps dropping frequently (less than 24hours after a full reset) and all internet TV services fail.
Also my smart home system drops out as a result so causes lots of problems.
Please can someone escalate this so I can get the firmware update.
All my details are in my profile
@DrDanParker
Gondola
Hi @DParker
The TalkTalk Community support team will return on Monday. Until then the best options for TalkTalk support are LiveChat or Messenger on the MyTalkTalk mobile app (8am to 10pm).
Request a firmware update to 1.22.1t for your HG633 router and they should be able to do that for you.
This topic is now also awaiting the attention of the TalkTalk Community support team of OCE's and they'll respond to you right here to help you with a follow up regarding the router firmware update.
Updates are delivered by Remote Management so just make sure your router has this re-enabled if you've previously switched it off.
Leave your router powered and connected to the line until the agents update or the OCE's reply here.  They'll check the HG633 router and either update to 1.22.1t or schedule an update via the update server.
 Gondola - I'm a TVPlus customer *
Hi DParker
Power off the router at the mains for 2 minutes, then back on and this should trigger a firmware update.
Check & Report l Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
