Help TV box
Sophs70
Hi can someone help please. TV Box wont turn on. It was working earlier but now nothing remote works. Can only find the on/off button at the back no reset. Anyone any ideas please
Sophs
Shazty48
Same issue here
fre55die
Hi @Shazty48
Could you please start your own thread for support as each problem is individual and needs investigating separately.
IMPORTANT
Could you please also ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information > Settings > Launch Profile Wizard,put your phone number in box, then scroll to the bottom of page and click save) Only you and the OCE's can view this information.
