Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Huawei youview tv box problems
1 REPLY
Trish5
This must be the 5th time that I've reported this one way or another, but here goes again.
Since the update last year my TV box has been sluggish and slow. A simple action like selecting the tv guide takes at least 1 minute to open. This is the same for all actions. TV guide, opening players or info, everything.
Obviously I perform all tthe usual actions, on/off switch at the back, resetting etc, but it's getting beyond a joke now.
Just wish TalkTalk had left well alone, as it was working perfectly fine before the update.
Try a Youview Maintenance Reset (Option 4: Keep Recordings).
Set the box back up and see if performance improves.
Check & Report l Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
