Huwai youview box volume
1 REPLY 1
Hi all,
When I set up my box and synced my tv remote I forgot to adjust the box volume to high, how can I adjust this?
Hi @Johncw99
Blue button on remote > Settings > Picture and sound. Set HDMI sound settings to Surround and volume will go to max.
