IPC6023 error message
TrudyK
Hi I am unable to access my Sky Sports boost as it states that there is a problem with this channel IPC6023. We have reset the router and also changed the youview box over to a new one but still no good. We can get netflix and iplayers and are accessing the internet ok on other devices. Please can you help.
Trudy
TrudyK
It to
TrudyK
i meant to add that i have an ethernet cable directly from the router to the talktalk box and that my router is HG633. I am very much a tech newbie so would appreciate your help - thank you!
Hi Trudy
Sorry for the delay, are you still having an issue with Sky Sports ?  Is it all channels or just a specific channel etc.
TrudyK
Hi Karl
It is all the Sky Sports channels that wont work and give the message. We are now also having trouble with the ondemand players and Netflix as they have no sound.
The line looks ok, no issues identified.  I've a replacement router on the way to rule this out.
Can you check the home phone and make sure the line sounds clear, with a clear dial tone?
TrudyK
Hi Karl
I've checked the home phone line and its fine - the tone is fine and clear.
Thanks for the update - i look forward to receiving the router and trying that.
Trudy
No Problem 🙂
Router could arrive tomorrow or friday.
TrudyK
Hi Karl
We have set up the new router but still had exactly the same problem - e.g. no Sky Sports channels and Netflix had poor picture and now sound. We've swapped back to our old router for now as this didnt seem to make any difference. What do we do now?
Many thanks
Trudy
Hi Trudy
I'll swap out the TV box for you.  Also, make sure that you use the new cables that came with the router.
TrudyK
Hi Karl
We have set up the set top box and it now all works! Netflix is working properly and so is Sky Sports. Thank you very much for your help with sorting this out.
Trudy
Glad to hear the new box has resolved things for you.
