Search instead for
Info button on v4 remote not working
1 REPLY
awalsh
my remotes not working at all just turns off and on
Gondola
Hi @awalsh
Could be that your TV Box is not responding.
Press and hold the front panel power / standby button for around 8 seconds or so until the front panel lights change.  Release and wait for the TV Box to restart. The remote should then be fully functional.
 Gondola - Community support team *
 To appreciate my support  . . .  If I helped with a solution Best Answer
