Internet tv Channels
ANSWERED
Hello. I have medium fibre but have never used the broadband tv option ( I cannot get freeview).
I have an older Huawei 360T Youviewbox/talktalk box. But have never used it. My question is what free internet channels would i be able to receive if i set it up?
Solution
Hi @Drachir
I believe that the only free ones that you will get are the catch up players I.E. BBC Iplayer, ITV Hub, All 4, My5, UKTV, S4C plus a couple of kids ones Milkshake and Pop Fun.
Thanks. Probably not worth setting up then as I already use a humax box with Freesat
