Itv anglia
1 REPLY 1
Libby68
How can I change from meridian to it Anglia news please.
I'm assuming you can get signals from both regions.
If so, then go to settings and TV channels and do a retune. You should then be asked to select your preferred region.
Alternatively, you may find an additional ITV channel in the 800 listings. This may be the one you are looking for.
Hope this helps.
