Search instead for
Keep losing picture on TV
PatAB
The picture on the TV keeps going off and only a black screen - on for 17 seconds off for 13 seconds.  This happens for hours at a time.  Sometimes the TV works normally.  We have tried turning off both the modem and the TV.
fre55die
Hi @PatAB
Just to clarify, does this happen when the TV is connected directly to the aerial?
PatAB
Yes connected to aerial.  Usually works OK during the morning and after 11pm at night.  Doesn't work when using playback when TV is cutting out.
fre55die
Hi @PatAB
If it's doing it when only the TV is connected to aerial then it's a TV problem.
