Losing picture and sound
ANSWERED
14 REPLIES 14
Wise Owl
While watching live channels the picture and sound cuts out for a couple of seconds, then returns. This happens every few minutes. The aerial goes to the talk talk box and then the TV. The TV picture and sound are fine. This happened last Thursday and Friday morning everything was fine. Box has been restored making no difference. Any further things I can try.
Try swapping the HDMI Cable, and if there are other HDMI ports on the TV, try a different HDMI port.
Wise Owl
Hi Karl
The aerial lead is connected to talk talk box then a HDMI lead to TV. This is how I watch the live programs, and there's no problems with picture or sound. I thought it might be software and tried reset keeping recordings and then full factory reset. No difference, the loss of picture and sound also on any recordings. Software is 72.48.87 last checked 5 Feb2020.  Have tried new HDMI in another socket also tried normal lead from box to TV, still same problem. Any further suggestions, perhaps someone has had similar problems. Thanks David.
If you have tried the Youview Maintenance Reset (Option 2: Keep Recordings), then you should try the full factory reset from the settings menu.
Wise Owl
Have tried that and a full reset. Have downloaded software. Making no difference. Tried new leads, the only thing I can't try is a different aerial though as the live TV works fine I don't see that can be the problem. I did switch box off and removed the plug. Left it for awhile before resetting. I'm at a loss of what else to do.
Thanks David.
We can try swapping out the box to see if that helps.  Do you want to try that?
Wise Owl
Hi Karl,
Yes please. I've sat and thought about it, I don't think it's router because I'm using the aerial. The only thing it can be is the box. Let's see if another box helps. Many thanks David.
Wise Owl
Hi Karl
Many thanks David.
Wise Owl
Hi Karl
Have received replacement box unfortunately it has been damaged. The aerial in socket is bent. Could you arrange another replacement please? I will return the damaged box by royal mail. Thanks David.
I'll gate a replacement out and a returns bag for the other unit.
Wise Owl
Hi Karl,
Received replacement box on Monday, everything seems to be fine. Thank you. Have returned damaged replacement will send faulty box on Monday. Thanks for your help. David.
Solution
Wise Owl
Hi Karl,
Have posted original faulty box today. Again many thanks. David.
