Lost channels
Emmalou2003
Visitor
Hi I have lost over half of my channels.  I have tried to return with no aerial attached as suggested by other people but it hasn't worked. Can anyone help??
Hi Emmalou2003
Have you checked the TV box signal quality? TalkTalk TV Box signal quality
fre55die
Hi @Emmalou2003
Have you had to retune recently for FREEVIEW channels as some transmitters are broadcasting on channels that need a new aerial ?
Do you get these channels if you plug the aerial lead directly into your TV ?
Check on the Freeview home page as I got Freeview to replace my aerial free of charge.
