Lost my subscription channels
PhilBest
At some point over the weekend, my Entertainment Boost subscription channels went from my guide & I cannot watch them anymore (simply gone altogether). I have re-tuned the youview box a number of times as well as turning it fully off at the mains. I have also run the softwear update (which states I am using the current versions), done a maintenance re-set (keeping recordings) and then done a full factory reset (via the settings menu). None of that seems to have worked. I have also turned my router off / on a number times - no help. My internet is still working as my mobile / laptop still connects and I can use the net plus the on-demend service still works for the likes of Netflix, BBC iPlayer and Sky on-demand. Checked 'My account' and that still shows my subscription as being active.
Any thoughts on what else I could do before I end up on the phone for a long time with customer support? Help from the community or OCEs would be appreciated.
Phil Best
Can you check now and see if the channels are back in the guide.
PhilBest
Hi Karl,
All channels are back in the guide and viewable / recordable. Thanks for sorting this for me.
Phil
Phil Best
Hi Phil
Glad its working now.
sswanscott
I have exactly the same problems as Phil, would it be possible you could  also fix my service that would be great.
my internet does work but very slow,but no subscription channels at all.
please advise
Hi sswanscott
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
