Missing Subscripton Channels
Mrlivingthedream
On my multiroom box, my subscription channels for SkyOne, MTV, Sky Movies etc. Are all missing. They are fine on my mainbox but missing from the multiroom box.
I can access the on demand services on the multi room box but the channels are completely missing. For example 301 is SkyOne and it just says “No channel”.
I have tried to reset the box but this has not resolved it. Please help me.
fre55die
Hi @Mrlivingthedream
Try blue button on remote > Settings > Software Information > Update Software
Have the channels returned ?  Do you need any further assistance ?
