My TalkTalk TV box has stopped working
6 REPLIES 6
Hi. My TV box has been problematic for the last few weeks. I've tried soft reset, hard reset, update software but the problems persist. It regularly turns itself off and I end up having to disconnect everything then reconnecting to get it to start up. I've done the factory reset a couple of times which hasn't gone down well as all previous recordings are wiped. How do I get a replacement box? My contract is due for renewal on 27th May, would I get e replacement when the contract is renewed ? Thanks for any help on this one
Oh, and also, the box regularly does not record programs and quite often the playback picture freezes but the sound continues and rewinding does not cure this problem.
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Thank you so much, that is greatly appreciated.
No Problem 🙂
Hi. My replacement TalkTalk TV Box arrived today and all seems to be working fine. There was no handset with the package but my old handset seems to be working with the new box. I notice in the setup instructions, the handset described has 'Menu' and 'More TV' whereas my old handset has 'YouView' and 'TalkTalk' buttons.
Are the functions of these buttons the same on both handset types ?
the functions are the same and you can use the old remote with the new box.
