My Youview box keeps disconnecting from the internet
24 REPLIES 24
My router is situated in another room to my Youview box so have to use connectors plugged into the mains socket, when box disconnects I have to unplug connectors and reboot the router and plug the connectors back in, this solves the problem for a little while and then the box disconnects again, very frustrating
Do you have the HG633 router running firmware V1.22t by any chance, as that firmware has a bug in it causing connectivity issues with a YouView box?
Thanks for your help, I do have a HG633 router, how do I find out what firmware it is running and if it is V1.22t how do I update it?
The easiest way now is for me to ask one of TalkTalk's OCEs to pick your thread up and upgrade it for you.
The forum is not real time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & Bank Holidays). Alternatively, you can call the call centre or use on-line chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Otherwise, TT will not be able to tie up your forum username to your broadband account. Only you & TalkTalk have visibility of your details.
 If you could ask one of TalkTalk's OCE's to upgrade my firmware I would be very grateful, thank you very much
I did, just moments after I replied to you.
Thanks Keith
Hi Nick
I've checked and your router is currently on V2 firmware.
Thanks Karl
I was hoping that was going to solve the problem, so it's back to the drawing board. Would having my router moved closer to the Youview box help so it can be connected direct?
Hi @Nick55
A direct connection to the router is always the best thing if physically possible.
Are your Power Line Adaptors connected DIRECTLY to the power sockets i.e. not using extension leads,surge protectors or adapters as any of these will degrade the signal and may cause the PLA's not working reliably, although if the router is crashing this will not help.
Is the router connected to your master socket or an extension socket?
Hi Fre55die
Thanks for replying. My PLA's are connected directly into the sockets, I don't think the router is crashing as other devises can continue to connect to the router by wifi.
When the box loses connection, do the light on the powerlines go off or red etc ?
Hi Karl
The lights on the powerlines are green when the box disconnects, sometimes constant sometimes flashing. When connected the two outside ones are green and the centre one flashes red
If the middle light is going red, this usually indicates the communication speed between them is dropping.
Have you tried swapping them round or resetting them.
You can hold a pin in the reset hole on each to fully reset, then re-pair the adapters and see if this happens again.
I'll give that a try and get back to you. Thanks
Hi Karl
I did as you suggested, reset the powerlines and changed sockets, it is still a poor connection as the middle light is red and they still disconnect but not as offten, I suppose this is the best I'm going to get
I'm going to swap out the powerline adapters to see if they are at fault.  A new set is on the way.
That's great, thanks a lot Karl. I'll let you know what happens when they arrive
