The TV sound works when I unplug the aerial from the myview box and plug it into the rear of the TV. When reconnected to the my view box no sound.
bestmanx3 wrote:Have you checked the volume level of the Youview box. Low volume when watching YouView
Thanks Bestmanx3 I have a sound bar, buts thanks anyway
Are you saying problem solved?
Have you enabled the Passthrough ? YV BUTTON > Settings > Picture and sound > Antenna Out Turn on.
If that doesn't work try
YV button > Settings > Picture and sound > HDMI and S/PDIF both set to surround.
How is Soundbar connected and what to ?
