Netgear D6400 VLAN Priority 1 TV Plus Internet Speed Help
SteveyMc
 I use a reliable Netgear D6400 with my TalkTalk Fast Fibre service rather than the supplied router. I recently upgraded to TV Plus and initially the Boost Channels would not work. Upon searching the forums before registration I stumbled across a solution to my problem. By default the VLAN Priority was 2 and would not work. The solution I found was to switch to Priority 1 and the Boost Channels worked immediately. Although the Internet is connected there has been a very noticeable drop in Line Speeds with much Slower Throughput.
 I was originally receiving speeds close to Max 79Mbps Down, 20Mbps Up, 21ms Ping but since the changes my profile has dropped to 52Mbps Down, 17Mbps Up, 46ms Ping. We notice with the drop in speed that when my young son using Xbox Live to play FIFA online the playable speed has become very slow and cumbersome with a longer button press delay.
 I have retried the HG633 but the overall perfomance to my home network with multiple devices connected is too restrictive and a great deal worse. Is there something I have missed within the Netgear D6400 settings or will my line speeds resync with DLM and increase in a number of days after these changes? Patience in the digital age isn't always easy to explain.
Any help would be greatly appreciated.
Gondola
Have you tried VLAN Priority 0?
The reason I ask is that 0 is the default and equates to 'best-effort'.
The equivalent Quality of Service setting usually recommended is UBR or unspecified bit rate which again is equivalent to 'best effort'.
I'm not saying that VLAN priority 1 doesn't work because I know that other members have found it works but I'm interested. I just don't have a Netgear to try it on.
 Gondola - Taking a little break *
SteveyMc
Thanks for your reply which I will attempt and reply with the findings. Kind regards
SteveyMc
 Hi Gondola, I changed VLAN priority to '0' and Subscription Channels still work. My line stats are still lower than previous though with Speeds, Latency and Throughput. My son has also tested Xbox Live and it is more playable than when the Router was on VLAN '1' but not as responsive as VLAN '2' which didn't work for Subscription Channels. Do you think my Line will Resync, improve and return to previous speeds? Are there any other changes possible that may help?
 Netgear Auto-Setup always detects and adds VLAN '2' by default which was obviously causing the issue. Further to the confusion when scouring the internet for VLAN Priority is the difference between PCP and Priority?
PCP Priority Acronym Traffic types
10 (lowest)BKBackground
01(Default)BEBest Effort
22EEExcellent Effort
33CACritical Applications
44VIVideo, < 100 ms latency and jitter
55VOVoice, < 10 ms latency and jitter
66ICInternetwork Control
7
7 (highest)NC
Network Control
SteveyMc
Hi Gondola, VLAN Priority '0' is having a negative impact on my overall fibre service. The TV Plus and Subscription Channels are working no problem but I am experiencing slower speeds, poorer throughput and increased latency on other connected devices. The changes are also causing disconnections from Xbox Live and Major Lag during gameplay. Are there any further suggestions you can offer or even recommend another router compatible with the talktalk tv service? Kind regards
Gondola
Hi @SteveyMc
Obviously reset to VLAN Priority 1 as this works for others.
Not having a Netgear to test with is somewhat of a disadvantage for me.
As for routers that will work with the TalkTalk TV Service and that are also approved for connection to the Openreach network the answer is easy. A TalkTalk Super Router.  It's supplied and maintained by TalkTalk.
SteveyMc
Thanks for the quick reply again @Gondola and all the help. Sadly I need My Router to offer much more than the provided HG633 Super Router.
The performance of the Netgear D6400 on VLAN '2' without a TV Plus & Subscription Channels worked flawlessly. Since upgrading my service it appears to be an issue with the Multicast/IGMP causing issues on my network.
If something doesn't quite work when it should I perservere until I find a solution. Hopefully I can delve a little deeper. Kind regards
SteveyMc
Hi again @Gondola I considered what you said about the Super Router and gave it another go. Although the wireless perfomance and available options are poorer than my Netgear D6400 it can run on VLAN '2' with TV Plus & Subscription Channels to provide a smoother experience with multiple devices. Perhaps a D6400 firmware update is required from Netgear to work better with IGMP/Multicast Traffic?
 Also, due to the Xbox Live service I have had to disable ICMP Flood Protection in the Firewall of the HG633 to stop Multiplayer Packets being blocked. Obviously my sons Xbox One needs to be Pingable Online but this appears the only option available on the HG633 to allow it?
 Finally I have found port 1024 shows Open with the Youview box when using grc shields up to Port Scan All Service Ports. Is this a Security concern knowing that the TalkTalk service has been breached in the past?
 I understand you may not be able to answer questions I've asked but perhaps our conversation may be of use to others? Kind regards
Gondola
Hi @SteveyMc
I'm not a gameplayer so don't know instantly what ports will be used with the XBox. I thought I'd better do a check of open ports here and there's no response on 1024.
I would advise a malware / virus scan just to make sure.  1024 is one of the common ports to find open with some trojans.
What firmware is your TalkTalk router running?
SteveyMc
Hi @Gondola
I'll post a Screenshot of the current Firmware Version. Thanks for the advice, I'll get straight onto running a scan, thanks.
Gondola
...HG633 is bang up to date with release firmware.
SteveyMc
Hi @Gondola I'm pleased the firmware is up to date. I've also completed a Full Security Scan and everything comes back clear. However after performing another scan of the service ports 1024 is still Open rather than Stealth. I've adjusted the zoom but hopefully you can see from the photo below
Gondola
Just rechecked with TV Box on and off and I still don't get a response from an online port scan. Port Scan.jpgPort Scan negative
Port 1024 is used by the TV Box that's for sure but it is a secure connection just for the TV box and so far as I can see not a route past the firewall into your pc.
You've checked that there isn't any other software holding the port open so that's comforting.
I've just looked at some other YouView forum posts and it does seem that ShieldsUp! does, in it's checking, flag up 1024 as open.  So whatever or however ShieldsUp! is checking I think it's a false positive as the router (my router anyway) doesn't have this port open for general traffic.
SteveyMc
Hi @Gondola, you're a credit to the community with all the time, quick responses, information and now reassurance with security you've given to me. I greatly appreciate the help and I'm sure you'll continue to be a big help to others too.
 I'll keep using the HG633 but I will contact Netgear support to see if they are aware of any D6400 issues regarding VLAN Priority & Multicast Traffic? You never know there could be a simple explainable bug in the firmware? I'll let you know if they do offer anything of importance that could also be of help to the community? Kindest regards and keep up the great work. Thumbs upWink
Chalkiejim
Problem Solver
I know this is an old thread, but have the same router as you.
I have mine set up with TalkTalk TV and it all works fine.
Just to let you know that when you subscribe to Talktalk TV boosts you do loose a bit of speed to stabilize the line, (2 Mbps approx).
If you are still having trouble hive me a reply and I will see if I can help.
Chalkiejim
jcheeseman757
Hello there, I have talktalk on a Netgear D6400 and when I am watching the boost channels I keep on getting an Error IPC6023 and IPC6017. Any idea's how to get this working? I plugged in the original router talktalk sent to me and it was working fine. I think it may have something to do with IGMP.
jcheeseman757
Hello there,
I have a talktalk ADSL connection using the D6400, internet is working great but the talktalk tv boost channels arent working so well. I keep getting errors IPC6023 and IPC6017 which is relating to my broadband connection but that is working fine. I have plugged in my original router that talktalk sent to me and that is working fine on the Boost channels so it suggests its an issue or setting that needs tweaking on my router. I think it may be something to do with IGMP.
jcheeseman757
Hi Chalkiejim,
How did you get your D6400 Router to work with TalkTalk TV with the boost channels? I've looked everywhere and I can't find any information on setting it up on this router? I think im having issues with IMGP, I've disabled with IGMP Proxy setting in the WAN but still no avail. Any help would be a great deal :)
Chalkiejim
Problem Solver
Are you on fibre or standard broadband.
jcheeseman757
Standard ADSL broadband
