No Broadband connection on YouView Box
ANSWERED
Kronik_Kay
I have a YouView box that has had an Internet connection fine for the last two years or so. It sudddenly stopped connecting to the Internet but connected to the router. I can ping the TV box but it replies intermittently, it has it's own reverved DHCP address, I have changed the cables, checked that other devices can connect to the Internet over the same cable and it all works fine. I have done a factory reset on the box which worked first time a few weeks ago to get it back on the Internet, it failed again. Factory Reset this time will now not connect to the Internet and I can no longer access any menu's on the box except the connect to Internet, which fails every time. I have spent many hours on chats to TT and now feel, as suspected originally, the NIC on the box is failing and now died. I did a Reset from the Maintenance mode, no joy, I did a software restore from Maintenance mode and this gets so far and stops, probably beecause there is no connection to download the software. Any help appreciated.
fre55die
Hi @Kronik_Kay
How is your box connected to the router ? Powerlines or Eternet cable ?
Kronik_Kay
Hi fre55die, it is via an ethernet cable to a switch then to the router via CAT5e. Cheers
fre55die
Hi @Kronik_Kay
I have escalated this for OCE support for you and they will respond here.
Hi Kronik_Kay
I'm unable to see the box online and no discovery logs are present.
I'll swap out the box and see if this helps.
Kronik_Kay
Hi Karl, thanks for this, are you sending a new box? Many thanks Christian
A new one is on the way.
Kronik_Kay
Hi Karl, many thanks for the box, arrived today. Connected it up with high hopes but the problem remains the same, however... I put the new ethernet cable in, rebooted the switch, restarted the TT router, still the problem remains. When selecting auto connect, the box obtains its reserved IP, says it has connected to the router but is unable to route out to the Internet.
I factory reset the TT router and the box connected long enough to obtain updates, and run through the setup screens. I went to update the players and apps as they were missing, it said they were all up to date, I went to the apps and it said there was no Internet connection and on the settings screen indeed the Internet had gone again. The set top box pings intermittently from PC's around the house with a 40% loss on 825 pings. The only thing I changed on the router was adding my NAS external access port (5001) but not sure if the Internet dropped before I did this. The router fyi is on Firmware 2.00t. I am at a loss now, if you have any suggestions please let me know. On a plus point, we can now watch Freeview :-) Cheers
You did not mention a switch.  Is the set top box direct to the router or connected to the switch ?
Kronik_Kay
Hello, yes it goes through a switch shared with the TV. Always has and never been a problem.. I am guessing you will ask to connect it directly so I will try and get round to that tonight.
Cheers
Christian
Solution
Some switches do not carry across the IGMP data required for IPTV services so you will often find that on demand programs work as these use standard internet data for this, such as any streaming service but IPTV (Live TV) relies on IGMP.
By passing the switch can rule this out.  Also, depending on the type of switch you have, check the manual or config to make sure it will handle IGMP data.
Kronik_Kay
Karl you genius, switched to a router that performs IGMP snooping, bingo, works.
Many thanks for your time with this, much appreciated.
Christian
Glad I've been able to help :)
Kronik_Kay
Thanks fre55die I have closed the case now, Karl helped me sort it out. FYI it is via a switch to the router.
Cheers
Christian
