No TV light showing on router. Unable to access on demand services on you view.
12 REPLIES 12
No TV light on router. Unable to access on demand services on you view.
Andrew ?
When you say on demand, can you access things like BBC Iplayer etc ?
How is the TV Box direct to the router, direct with a cable or are you using powerline adapters.
Hi, I'm unable to access any of the online players such as BBC iPlayer. Our set top box is connected to our router by cable. Hope this helps.
Regards, Andrew.
Andrew ?
Can you try another ethernet cable and try other ports on the back of the router to rule out a faulty cable / port.
Hi, I've tried other ports and no joy with the set top box. We have a hive device connected to the router and this works fine in another port. Unfortunately we don't have a long enough cable to reach the set top box or able to move the router closer. If there is a problem with the cable would the TV light on the router still show?
Andrew ?
Is the TV connected via powerline adapters ?
Are all lights green on the adapters ?
Hi, apologies for my lack of tech knowledge. What is a power line adapter? The set top box is connected to the socket by its plug. The set top box is connected to the router by ethernet cable and to the TV by hdmi cable. The green lights on the router are always flashing above internet, wireless and ethernet. Sometimes the green ethernet light goes out for very short periods.
Hope this helps.
Regards, Andrew.
Andrew ?
powerline adapters are little plug in adapters that allow the TV box or other devices to receive the signal from the router over your electrical network.
This short video may explain better : https://www.youtube.com/watch?v=b3Seqv1acS4
Hi, definitely don't have any of those. Just an ethernet cable from set top box to router.
Regards, Andrew.
Andrew ?
I've a router on the way to you so we can see if this is failing.
Hi, just had notification from DHL the router will be delivered tomorrow (Tuesday 28th). Thanks.
Regards, Andrew.
Andrew ?
Hi, the router arrived yesterday. All set up and all is working. Full service is resumed with the set top box. In fact the internet seems slightly faster.
Thanks for your time in sorting this for me.
Regards, Andrew.
Andrew ?
That's great news, thanks for confirming.
