No audio control via SCART - DN360
andypag
The volume control on my Youview box Huawei DN360 has no effect on the audio out via SCART. I have it connected to an amp. I use the HDMI to connect to a projector.
Is there a setting I need to change? Or is this a fault which will be addressed with an update? This box has been out for 2 years.
Andy
andypag
UPDATE: I realised that when I switch the projector off, (or unplug the HDMI) the scart output does then revert to controlled volume level.
This still doesn't help me as I'd like to be able to control the volume through my amp while watching the projector...
Any suggestions? Any Talktalk people monitor these forums for bugs?
Andy
andypag
Does anyone know if there is the same issue with the SPDIF output? I could get an SPDIF to RCA converter and connect to the amp that way, but don't want to spend the money only to find volume isn't controlled on the SPDIFF output either while HDMI is active.
