No boost channels
Hi all Just set up today with router and TV box everything's working as it should except I've got no boost channels in the guide, am I doing something wrong there's a good aerial connection cracking picture, good Internet connection but all I have is the standard channels thanks in advance
Silly question time, but is your box attached to the router, either directly or by power line adaptors?
If so, then the box is on and you push the Menu button, for a it say TalkTalk?
If Yes to both then you should see the channels on the guide irrespective of whether you have the boosts or not. Try a return from the settings menu to see if it pulls them through.
If that does not work, then try a soft reset. To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347).
Hope it works but if not then please let us know and I’ll flag for further assistance.
Hi Fraserm
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
