Powerline Adapters displaying no lights
9 REPLIES 9
Hello there
can anyone help me please my
Powerline Adapters are displaying no lights
many thanks
Hi markyd
Are ther no lights at all them.  I guess you should have at least the power light on with each one.  If not, maybe the mains socket itesf is no longer live for some reason.  You could unplug the offending one and try it in a known good power socket.
PS - just saw this guide.
https://community.talktalk.co.uk/t5/Articles/Fix-a-problem-with-your-Powerline-adapters/ta-p/2205308
Hello Walter25
Just to confirm that NO lights are working and I have tried the adapter in another socket but to no avail
thanks for your reply
Hmm, it does kinda sound like it's expired (met it's maker), unless someone else knows a good trick to get it going.  Sorry I cant help you any more than this.  Stupid question, but I don't suppose you could run a network cable instead could you?  Much more reliable...  Looks like you're not the first with this problem:
https://community.talktalk.co.uk/t5/TalkTalk-TV/Powerline-Adapters-displaying-no-lights/td-p/2227721
Should Talktalk renew the adapter or do I need to buy new ones?
Hi @markyd1981
If you swap the PLA's over and press either the reset button or if there is a pin reset do this whilst plugged in. As in the previous comment fron @Walter25, there should be at least a power light on at least one of them, unless a power surge or something has killed them both.
Regarding the replacements, Where and when did you get them from, (I.E. Did you get them from TT or somewhere else ?)  What make and model are they?
Hello fre55die
Both adapters where supplied by Talktalk 2-3 years ago when the Talktalk TV box was first installed.
Both adapters show no lights whatsoever.
Both adapters are Talktalk D-Link model No-DHP 300AV
thanks for your help
Hi @markyd1981
I have escalated this for OCE support for you and they will respond here.
many thanks @fre55die
Hi markyd1981
"Both adapters where supplied by Talktalk 2-3 years ago when the Talktalk TV box was first installed.
Both adapters show no lights whatsoever"
Apologies for this. The warranty period for this would be 12 months.
