I have a message saying my TV can't connect to my router. All was fine 2 days ago. I've tried turning everything on, off, reset, different sockets etc etc but can't get it to reset.
I've noticed that the one of the adaptors doesn't have any lights showing on the front of it as it usually does. Could it be it has just 'died' and I need a replacement?
How can I get one?
Try resetting the adapters and pairing them side by side in a double wall socket, then put them back in place.
If they fail to pair when side by side then they will need to be replaced.
