Problems with tv plus box.
11 REPLIES 11
markdandav
I am now getting fed up with having to reset my plus box and re-set it up every day, so I can record and watch itv hub.
Please send a new box.
Thanks Mark.
OCE_Debbie
Hi Mark
I've sent a replacement TV Box for testing, please allow 24-48hrs for this to arrive.
markdandav
Thank you.
I will keep you informed.
OCE_Debbie
markdandav
Received Plus box today, will be setting it up later tonight, and will let you know how it goes.
Mark
markdandav
Just a quick update, plus box seems to be working as it should.
The only problem now is I can now no longer get the Sky channels.
Mark
OCE_Michelle
Hi Mark,
Thanks for the update. What happens when you try to access these channels? Do you receive any error messages/codes?
markdandav
It just comes up with no channel, have re-tuned box several times.
Mark
OCE_Michelle
Hi Mark,
Apologies for the confusion, are the channels showing in the guide? Is this all sky channels? When you click on a specific channel you just get a blank page? This was also working fine until you replaced the box?
markdandav
Not showing in tv guide, when you put the number in the number comes up on the screen for about 15-30 seconds then disappears, they were all there on the old box.
Mark
markdandav
All Good now just did an update on box and all back now.
Thanks for all the help.
Mark
OCE_Debbie
Hi Mark
That's great, please let us know if you do experience any further issues.
