Random channel changing
5 REPLIES 5
JAKE12
I have the same problem as a post by bbriggs (10-9-2018) with random continual channel
changes.
I have tried all the suggested fixes, including resets, with no success.
I have tested the box on another setup but the fault remains.
I have used a borrowed box on my setup and it was perfect.
Does this indicate that my box has failed?
Kind regards, Jake12.
This does indicate a box issue.  I'll get this swapped out for you.
JAKE12
Many thanks, Karl, for your superfast reply and action.
Take care, kind regards, J12.
JAKE12
All working fine for the past day, many thanks to those who got the replacement to me so fast.
Kind regards, J12.
Thanks for confirming.
