Search instead for
Re: Pixellating programmes.
Paul661
Tv pixelating and losing connection. Have rebooted router and reset to box.tv guide still shows. We are running the 633 router.we had the same problem before X mas.A new TVs box fixed the problem at the time.
PaulH
Have you tried using the Dlink router ?
Do any other devices lose connection ?
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Paul661
Hi Karl. Everything else connected to Internet work ok. Dlink router works ok but will not connect.we tried this router before Xmas without any success. Still using the old 633 router.this has worked fine up to the last couple of weeks.cannot understand why Dlink router won't play internet channels .Tv light does not come on
PaulH
I've asked our network team to have a look at this line.  I'm seeing an increase in resistance on the line.
Paul661
Ok Karl .Thanks for your response
PaulH
No Problem 🙂
Will post back when they reply.
Networks advise there is an increase of errors and they have asked BT to change the DLM setting to increase error protection to see if this helps.
This should be actioned in the next 48 hrs.
Paul661
Thanks Karl .will see how it goes over the next few days
PaulH
Paul661
Hi Karl . Everything working ok at the moment .hopefully it will stay that way.
PaulH
Hi Paul661,
Thanks for the update and let us know if you need any assistance :)
