Hi, first time post so please be gentle!
Just bought a new tv, 40 inch Blaupunkt, and can't get me TalkTalk V4 remote to pair with it. I've tried all nine codes on the Talktalk website but no luck.
I've also tried an online chat with on of their agents, but mistake! Waste of time totally.
Has anyone any clues? Thanks in advance.
The tv is a 40/1330-WB-11B-FEGB-UK
Blaupunkt codes are difficult to find, the one that worked for my TV was 1775
Thanks, I tried that but no luck.
Talk Talk's helpline staff are worse than useless!
OK. The TV codes we have on our website are the codes supplied to us by the manufacturers. All I can suggest is a google search and see if anyone has discovered a code that may work for your model.
Success, I found a code on another forum that worked, 2106.
Excellent, thanks for sharing, it may help someone else looking for a code to try.
