Require engineers manual for DN370T under EU/UK Right to Repair law
5 REPLIES 5
CriminalsRunTheWorld
How can I get an engineers manual for the Huawei DN370T STB so that I can repair it under the EU/UK Right to Repair law? Its a device supplied by TalkTalk so consumer rights contract would be with TalkTalk but dont know if I have to go to Huawei to get the manual as they manufactured the device.
I dont want to break any plastic tabs once I've unscrewed it, so that I can get to the bottom of why the device is failing to record properly after its latest firmware update a few weeks back when the coronavirus lockdown kicked in.
I've contacted Youview for the source code so I can go through that as they are using various open source Linux librarys to provide the TV STB experience, which they have not answered yet by just asking what the problem is.
Unfortunately TT telephone support is not satisfactory, agents cant deviate from the script provided to them.
TIA.
OCE_Karl
Opening the box can remove any warranty.
For a manual, you will need to contact the manufacturer directly.  This is not something we have access to or supply.
Just curious, what warranty does it have if its years old?
Its well beyond any manufacturer warranty, so do TalkTalk provide an extended warranty?
I'll contact HuaWei and see where that leads me.
Emailed them using this form https://consumer.huawei.com/uk/contact-us/ so I will see where this goes.
OCE_Karl
We only provide a warranty with the contract, so usually we will replace if its broken eyc, within the first 18 months, outside of this is discrencianary.
We are out of contract, but I dont think you can fix the Youview software, so the ball is out of your court so to speak anyway.
Thanks for the info.
