Second TV Plus Box Even Worse
7 REPLIES 7
We were sent a replacement TV Plus box around 2-3 months ago now as our old one kept switching off and was having problems recording.
The replacement box was working fine until about 3 weeks ago. Recordings are not always recording, the box freezes 2-3 times a day, sometimes when you are watching a recording it will suddenly freeze and then throw you back to the main screen and when watching live TV the picture will also just freeze for sometimes 5 minutes at a time.
Have tried everything, including a factory reset (losing all of our recordings in the process which is far from ideal).
Obviously we are starting to get very disillusioned with this service now. We pay for the Entertainment Boost and Sky Sports and it is becoming a task to watch TV. My other half is a big football fan and it is ruining his experience completely, why pay for Sky Sports if it not watchable?
I am not sure what help can be given because if another box is sent yet again i am worried it will work for a month and then fall into this state again. We were also sent a new router 6 weeks ago for a separate problem so our Broadband should be fine.
I look forward to hearing from you.
Kind regards
Hi HelloTeale87
How is the TV Box connected wired or using powerline adapters?
Hi Debbie
Thanks for replying.
The TV Box and Router are right by the TV and are wired. No Adapters used.
Many thanks
If the TV box has been fully reset and the issue continues then the only option we have is to replace the box in case the unit has become faulty.
Hi Kevin
Ok thanks, we will go down that route again then.
can you confirm please?
thanks
replacement is on the way.
Many thanks
No Problem 🙂
