Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Sky cinema boost - tv jumping from film to normal tv constantly
Danielbladen1
Sightseer
Hi, I am watching a film on sky cinema on demand. The tv keeps jumping from the film to normal Tv channels. I then have to go back onto my boosts in search for the film again and resume. This has happened 3 times already and I'm only 40 minutes into the film.
Anyone else experiencing this problem?
fre55die
Hi @Danielbladen1
By "normal TV channels" do you mean on the TV or is the YV box switching to terrestial or "boost" IPTV TV channels ?
Danielbladen1
Sightseer
Hi, it switches from cinema boost to any channel that can be found on guide on the talk talk box
Hi Daniel,
This is really strange behavior.
Could you try a Youview Maintenance Reset (Option 4: Keep Recordings).
set the box back up and retest and see if this still happens ?
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
