Search instead for
Sky sports boost not working
mrmadcat
I subscribed to Talk Talk tv with skyt sports boost. The box arrived nice and easy set up, Sky sports working fine till last Sunday but not had any sports channels since. I am realy peeved as wanted to watch footy and this weekends F1. Spent nearly 2 hours reseting ect with tec but stiull no sports channels can anyone help ?.
Never argue with idiots they will only drag you down to their level and beat you with experience.
mrmadcat
My Sky sports boost was working fine but it went off last Sunday and now just blank screen. Spent 2 hours trying to sort with tec to no avail.
Gondola
Hi @mrmadcat
In addition to a soft reset (front power / standby button press for 8 seconds) Have you tried the usual related troubleshooting:
  • Reboot the router
  • Check the broadband speed
  • Connect the TV Box to the router with Ethernet cable
I've drawn this topic to the attention of the TalkTalk Community support team of OCE's and they'll respond to you right here to help you.
 Gondola - Community support team *
 To appreciate my support  . . .  If I helped with a solution Best Answer
Hi mrmadcat
All settings look ok from here.  Another router is on the way to rule out an issue with htis, as the current router is a couple of years old.
This should arrive soon.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
