Sky sports pixelation
4 REPLIES 4
Often when I am watching sky sports pixekation occurs that make it unwatchable. Also every second or third day my speed drops to as low as 8mbs when I usually get about 25mbs. Switching off the router, then back on again seems to fix the problem short term. However, I am paying for a service that is poor. My router is Huawei Hg633 and I am on fibre. This issue is getting to the point that I may have to leave talk talk.
Biggles flies again.
I'm not seeing any issues with the line itself, all tests are showing clear.
I've a new router on the way to rule out a hardware issue.
Cheers.
I had this problem for 6 months, I've just upgraded to new TT Hub router and its now working perfectly.  Also much better on all fronts.
Cheers
Iain
Cheers, should give that a try.
