You view box stopped recording and has been factory reset twice.
1st time we kept the recordings
2nd time we reset the lot still it didn't solve the issue.
It's been about a week since then and now the box won't turn on at all.
I've checked the connections and plug for issues.
What can I try?
I'll get a replacement TV box out to you.
