I have just moved into a new property and signed up to talktalk. I was able to connect the internet no problem but I am struggling to connect the TV box. There is no place to plug in the aerial cable supplied with the equipment. There is an old NTL box on the wall but the plugs are all different sizes. Do I need to call out a specialist?
Any advise much appreciated!
Solved! Jump to the Best Answer.
The TalkTalk Bax will only work with a traditional external TV aerial. It cannot work with the the connection you are showing which would be for Cable or Satellite connection.
If you do not have an aerial connection in the property, you will need to contact a local installer to discuss your requirements.
