Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Subscription Channels
Bodo1260
My subscription channels frequently break up.. the lower portion of the screen becoming pixellated.  There is no pattern to the interference, if i reset the router it resolved for a few hours.
Gondola
Hi @Bodo1260
I've drawn this topic to the attention of the TalkTalk support team and they'll come back to you right here.
I see that Karl updated the router firmware only a couple of weeks ago.  The symptoms of screen pixellation on live streamed channels indicate low broadband speeds. You need a minimum consistent speed of 5Mbps all the way to the TalkTalk TV Box to ensure no picture break-up.  If your TV Box is connected to the router by Powerline adaptors are the led's green all the time?
TalkTalk have produced a little video about improving home broadband speeds. Have a look and see if you can identify with any of the issues there.
As it says in the video, the TalkTalk supported routers are updated automatically and yours should have the latest available firmware.
Try a speedtest.  Preferably with the router connected to the master socket or even better a test socket
Try a fast speedtest try: Fast (Click here)
Or the TalkTalk speedtester that you can log your number so TalkTalk can see your results: Supportal (Click here)
To check the router statistics open a browser on a connected device, log in to the router interface and follow the instructions here: click here: Sync Speed.
The OCE will check your line and router performance to see if there are any underlying issues.
 Gondola - I'm a TVPlus customer *
Hi Bodo1260
Router is in sync at 35mb and all line tests are clear and show no errors.
Check your phone line is clear.
If the youview box is connected with a cable, try a different cable or router port.
If using powerline adapters, make sure these are directly into wall sockets.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Bodo1260
I am getong 15MBs... so speed is OK...
Is the youview box direct to the router or via powerline adapters ?
Bodo1260
Hi there..
it is a direct connection.
cheers
Speeds are showing as 35.5mb currently, can you run a couple of wired (not wireless) speed tests via https://myaccount.talktalk.co.uk/speed-checker/  and log against your home phone number so I can see your throughput speeds.
Bodo1260
OK I have done the test three times
8ms - 15.9MBps - 8.1MBps
8ms - 17.4MBps - 8.3MBps
7ms - 17.1MBps - 8.3Mbps
I'm not showing any speedtests logged against your account, did you log these with your full home phone number in My Account.
Bodo1260
OK, i tried again and did the test three times.. the speeds were not very impressive.
the figures should show as being logged now
I'm not showing any speedtests logged here.  Did you enter your full home number including area code.
We do need the speed test results to be logged before we can pass the issue to our network teams.
Bodo1260
I have done another speed test using the link above, i'm getting just over 20MBps
It did not ask for my phone number
Can you log into My Account  and run the speed test from there.
Bodo1260
i've done that again.... the last speedchecks were done through 'my account' anyway
Can you confirm all tests were run wired with no other devices connected.
Can you also download and run this Network Test and PM the results to me.
Bodo1260
the TV box was still wired in but not on, ?standby?
Bodo1260
I have run the new test
i have tried to PM you but i can't seem to get a text box to copy into
Try now, I've adjusted your pm access.
Bodo1260
thanks.... i have sent it to you now
I've passed these results over to our network teams to look into.
